Inovance Drives
19 K
Aug 05, 2024 12:48 pm
Inovance drive error codes explained. Easy-to-understand guide for diagnosing and fixing common drive faults. Improve equipment uptime.
Inovance drive error code list:
- Err23 fault in inovance drive - Cause : "Err23" is displayed at power-on comes when motor or motor output cable is short circuited to ground or hardware issue in drive.
- HC fault in inovance drive - Cause : "HC" is displayed while power-on comes when wire between drive board and control board is in poor contact or hardware issue in drive power card or control card.
- Err62 fault in inovance drive - Cause : Short-circuit of braking circuit comes when hardware issue in drive brake chopper circuit or braking IGBT is abnormal.
- Err61 fault in inovance drive - Cause : Braking unit overload comes when the drive's internal braking transistor reached it's overload level. When a resistor is overloaded then drive displat fault "Err61" it attempts to dissipate more heat than it was designed to do.
- Err45 fault in inovance drive - Cause : Motor overtemperature comes when motor is overloaded or load duty cycle is exceeded. " Err45" indicate a warning or alarm generated by a motor or drive that indicates the device is too heated.
- Err43 fault in inovance drive - Cause : Motor overspeed comes when encoder parameters are set improperly, motor auto-tuning is not performed or F9-67 (Overspeed detection level) and F9-68 (Overspeed detection time) are set incorrectly.
- Err42 fault in inovance drive- Cause : Speed error comes when encoder parameters are set improperly, motor auto-tuning is not performed or F9-69 (detection level of speed error) and F9-70 (detection time of speed error) are set incorrectly.
- Err41 fault in inovance drive- Cause : Motor switchover fault during running comes when motor switchover via terminal during drive running of the AC drive.
- Err40 fault in inovance drive- Cause : Pulse-by-pulse current limit fault comes when load is too heavy or locked-rotor occurs on motor or the AC drive power class is small.Â
- Err01: Drive unit protection- This fault indicate hardware issue in drive.
- Err02: Acceleration over-current.
- Err03: Deceleration over-current.
- Err04: Overcurrent at constant speed.
- Err05: Acceleration over-voltage.
- Err07: Overvoltage at constant speed.
- Err08: Control power supply fault.
- Err09: Undervoltage.
- Err10: AC drive overload.
- Err11: Motor overloaded.
- Err12: Power input phase loss .
- Err13: Power output phase loss.
- Err14: Module overheat (IGBT).
- Err15: External fault (digital input).
- Err16: Communication fault .
- Err17: Encoder fault.
- Err18: Current detection fault .
- Err19: Motor auto-tuning fault.
- Err21: EEPROM read-write fault
- Err22: AC drive hardware fault.
This is a comprehensive list of Inovance drive error codes. Quickly troubleshoot and resolve common issues.
