Err11 Motor overload fault in inovance MD200 drive
Cause : Motor overload comes when the output current exceeds the motor full load current set in parameter. A motor overload occurs when a motor is subjected to excessive load or stress beyond its design capacity, leading to overheating and potential damage.
"Err11" fault in inovance MD200 drive indicate "Motor overload" condition. This means a motor is asked to deliver more torque or current than it is rated for. This can lead to overheating, reduced efficiency, and potential damage to the motor or connected components.
Common Causes
  • Excessive Load: The motor is being asked to drive a load that exceeds its rated capacity.
  • Mechanical Issues: Problems such as bearing failure, rotor imbalance, or misalignment can increase the load on the motor.
  • Power Supply Problems: Fluctuations or insufficient power supply can limit the motor's output.
  • Drive Configuration Errors: Incorrect settings in the drive, such as current limit or torque control, can contribute to overloading.
Troubleshooting Steps
  1. Verify Motor Load:
    • Check the load on the motor: Ensure that it is within the motor's rated capacity.
    • Measure the actual load torque: Use a torque wrench or other appropriate methods to determine the load.
    • Compare the measured load to the motor's rated torque: If the load exceeds the rating, reduce it or replace the motor with a more suitable one.
  2. Inspect Mechanical Components:
    • Check for mechanical damage: Look for signs of wear, damage, or misalignment in the motor, coupling, or driven equipment.
    • Test the motor's bearings: Use a stethoscope or vibration analyzer to detect abnormal noises or vibrations.
    • Balance the rotor: If necessary, balance the motor's rotor to prevent excessive vibration and current draw.
  3. Verify Power Supply:
    • Measure the input voltage: Ensure that the input voltage to the drive is within the specified range and stable.
    • Check for voltage fluctuations: Use a power quality analyzer to detect any voltage spikes or dips.
    • Improve power quality: If necessary, install a power conditioner or uninterruptible power supply (UPS) to stabilize the power supply.
  4. Review Drive Configuration:
    • Check current limit: Ensure that the current limit is set to a value that allows the motor to operate without overloading.
    • Verify torque control: If the drive uses torque control, make sure that the torque setting is appropriate for the load.
    • Review other drive settings: Check for any other configuration errors that might be contributing to the problem.
