Inovance MD800, MD500 & MD880 Drive
421
Sep 06, 2024 5:06 am
Cause : AC drive axis type identification setting error comes when there is an issue with the axis type configuration or identification process.
"E01.07" in inovance MD800 drive indicate "AC drive axis type identification setting error". This means the drive cannot correctly identify or configure the axis type, which is essential for proper motor control.
Check Axis Type Configuration:
- Verify the axis type settings in the drive parameters. Ensure that the correct axis type is selected based on the motor you are using.
- Refer to the drive's manual to confirm the correct parameter settings for your specific motor and application.
Verify Motor Compatibility:
- Ensure that the motor connected to the drive is compatible with the axis type setting you have chosen.
- Check the motor's specifications and compare them with the drive’s requirements.
Update Firmware:
- Ensure the drive is running the latest firmware. Update the firmware if necessary to resolve any potential bugs or compatibility issues.
Check Hardware:
- Inspect the drive and motor for any signs of damage or wear that might prevent correct axis identification.
- Test the motor with another drive, if possible, to rule out motor issues.
Reset and Reconfigure:
- Consider resetting the drive to its default settings and reconfiguring the axis type from scratch. This can help clear any incorrect settings that might be causing the error.
