E16.02 fault in inovance MD800 drive
"E16.02" fault in inovance MD800 drive indicate the protective cover for the connector is not installed. This means the cover protects the connector from accidental contact, which could lead to electrical shock or damage to the drive.
  1. Locate the Missing Cover:
    • Carefully inspect the drive and its surroundings to find the missing cover. It might have fallen off or been misplaced.
  2. Check for Damage:
    • If you find the cover, examine it for any damage (e.g., cracks, broken tabs). If damaged, it may need to be replaced.
  3. Install the Cover (if found):
    • Align the cover with the connector and gently snap it into place. Ensure it's securely fastened.
  4. Obtain a Replacement Cover:
    • If the cover is not found or damaged, contact Inovance's customer support or a local authorized dealer to order a replacement. Provide the drive's model number and the specific part number of the cover.
