Inovance MD800, MD500 & MD880 Drive
261
Sep 06, 2024 6:07 am
"E16.03" fault in inovance MD800 drive indicate Station number allocation fails. This means the drive is unable to communicate with the master controller or other devices on the network.
Check Network Connectivity:
- Verify the physical connections of the network cables, ensuring they are securely plugged into the drive and the master controller or network switch.
- Use a network cable tester to check for continuity and verify that the cables are functioning correctly.
- Inspect the network switch for any error lights or indications of problems.
Verify Communication Parameters:
- Ensure that the communication parameters (baud rate, parity, stop bits, etc.) are configured correctly on both the drive and the master controller. Refer to the drive's user manual for the default settings and any required modifications.
- Use a communication software (e.g., Modbus poll) to test communication between the drive and the master controller.
Check for Address Conflicts:
- Verify that the station number assigned to the drive is unique on the network. Avoid using the same station number for multiple devices.
- Consult the network configuration documentation to determine the available station numbers.
Test Hardware Components:
- If the issue persists, try swapping the network cable or NIC to rule out hardware failures.
- If the problem is still present, consider replacing the faulty component.
