Inovance MD800, MD500 & MD880 Drive
282
Sep 06, 2024 6:08 am
"E16.04" fault in inovance MD800 drive indicate Continuous frame loss occurs on the extension card. This means a communication problem between the drive and the external device connected to the card.Â
This could be due to various factors, including:
- Hardware Issues: Faulty extension card, damaged cables, or incorrect connections.
- Software Problems: Incorrect configuration of the extension card, communication parameter mismatches, or software bugs.
- Network Interference: Noise or interference on the communication channel.
- Device Compatibility: Incompatibility between the extension card and the external device.
Check Hardware:
- Inspect the extension card for any physical damage or loose connections.
- Verify that the cables connecting the extension card to the drive and the external device are securely plugged in.
- Use a cable tester to check the integrity of the cables.
- If possible, try using a different extension card or cable to isolate the problem.
Verify Software Configuration:
- Ensure that the extension card is correctly configured in the drive's software. Refer to the drive's user manual for specific instructions.
- Check that the communication parameters (baud rate, parity, stop bits, etc.) match between the drive and the external device.
- If the extension card uses a specific protocol (e.g., Modbus, CANopen), verify that the protocol settings are correct on both devices.
Check for Network Interference:
- If the extension card is connected to a network, try moving it away from other electronic devices that might be causing interference.
- Use a shielded cable to reduce the susceptibility to electromagnetic interference.
Test Device Compatibility:
- If possible, try connecting a different external device to the extension card to see if the frame loss persists.
- If the problem is specific to a particular device, it may be incompatible with the extension card or the drive.
