E16.13 fault in inovance MD800 drive
"E16.13" fault in inovance MD800 drive indicate Data exchange from the power supply unit to the drive unit times out. Data exchange timeouts between the power supply unit (PSU) and the drive unit indicate a communication problem.
This could be due to various factors, including:
  • Hardware Issues: Faulty cables, connectors, or internal components in either the PSU or the drive.
  • Software Problems: Incorrect communication parameters, firmware issues, or software bugs.
  • Power Supply Issues: Insufficient power output, voltage fluctuations, or overload conditions.
  • Drive Unit Issues: Internal faults or configuration problems in the drive.
  1. Check Hardware Connections:
    • Ensure that all cables connecting the PSU to the drive are securely plugged in.
    • Inspect the cables for any physical damage or signs of wear.
    • If possible, try using different cables to isolate the problem.
  2. Verify Power Supply Output:
    • Use a multimeter to measure the output voltage and current of the PSU.
    • Ensure that the PSU is providing sufficient power to the drive.
    • Check for any voltage fluctuations or overload conditions.
  3. Inspect Drive Unit:
    • Examine the drive for any physical damage or signs of overheating.
    • Check for loose connections or internal components that might be faulty.
  4. Check Communication Parameters:
    • Verify that the communication parameters (baud rate, parity, stop bits, etc.) are configured correctly on both the PSU and the drive.
    • Refer to the user manuals for both devices to ensure consistent settings.
  5. Update Firmware:
    • Ensure that both the PSU and the drive are running the latest firmware versions. Outdated firmware can sometimes cause communication issues.
  6. Test with a Different PSU or Drive:
    • If possible, try using a different PSU or drive to isolate the problem.
