Inovance MD800, MD500 & MD880 Drive
333
Sep 06, 2024 6:35 am
"E16.21" fault in inovance MD800 drive indicate "CANlink heartbeat times out". A CANlink heartbeat timeout indicates a communication problem between the drive and the external device connected via the CANlink interface. This could be due to various factors, including:
- Hardware Issues: Faulty CANlink interface, damaged cables, or incorrect connections.
- Software Problems: Incorrect CANlink configuration, communication parameter mismatches, or software bugs.
- Network Interference: Noise or interference on the CANlink bus.
- Device Compatibility: Incompatibility between the drive and the connected device.
- Check Hardware:
- Inspect the CANlink interface on the drive and the connected device for any physical damage or loose connections.
- Verify that the CANlink cables are securely plugged in and that they are shielded to minimize interference.
- Use a cable tester to check the integrity of the cables.
- If possible, try using a different CANlink cable or interface to isolate the problem.
- Verify Software Configuration:
- Ensure that the CANlink communication parameters (baud rate, data rates, error checking) are configured correctly on both the drive and the connected device.
- Check that the heartbeat timeout settings are appropriate for the specific application.
- Refer to the user manuals for both devices for detailed configuration instructions.
- Check for Network Interference:
- If the CANlink bus is shared with other devices, try isolating the drive and the connected device to eliminate interference.
- Use shielded cables and proper grounding techniques to reduce the susceptibility to noise.
- Test Device Compatibility:
- If possible, try connecting a different device to the CANlink interface to see if the heartbeat timeout persists.
- If the problem is specific to a particular device, it may be incompatible with the drive or the CANlink network.
