E16.22 fault in inovance MD800 drive
"E16.22" fault in inovance MD800 drive indicate a CANlink station number conflict occurs. A CANlink station number conflict occurs when multiple devices on the CANlink network are assigned the same station number. This can lead to communication errors, data corruption, and system instability.
Potential Causes:
  • Incorrect Configuration: The CANlink station number might be set incorrectly on one or more devices.
  • Device Conflicts: Multiple devices on the network may have been assigned the same station number by default or due to manual configuration.
  • Network Topology Changes: Changes in the network topology, such as adding or removing devices, can sometimes lead to conflicts if station numbers are not updated accordingly.
  1. Verify Station Numbers:
    • Use a CANlink monitoring tool or diagnostic software to check the station numbers of all devices on the network.
    • Ensure that each device has a unique station number.
  2. Check Device Configuration:
    • Review the configuration settings of each device to verify the assigned station number.
    • Correct any inconsistencies or errors in the station number settings.
  3. Update Station Numbers:
    • If you find conflicting station numbers, assign unique numbers to all devices on the network.
    • Refer to the user manuals for the devices involved for specific instructions on how to change the station number.
  4. Check Network Topology:
    • If recent changes have been made to the network topology, ensure that the station numbers of all devices are still correct.
    • Update station numbers as needed to avoid conflicts.
