Inovance SV660P, S810N & IS620P Servo Drive
595
Nov 15, 2024 12:14 pm
Cause : Output short-circuit to ground comes when power output cables (UVW) of servo drive are short-circuited to ground.
Er.210 fault in inovance IS650 servo drive indicates Output short-circuit to ground. This means there's a short circuit between one of the motor phase wires (U, V, or W) and the ground.
- Inspect the motor cable for cuts, abrasions, or signs of excessive heat.
- Ensure that the motor cables are connected correctly to the drive terminals.
- Verify that the motor and drive are properly grounded.
- Re-connect these cables or replace them.
