Er.A35 fault in inovance IS650 servo drive
Er.A35 fault in inovance IS650 servo drive indicates Z signal lost. This means Z signal gets lost because of encoder fault.
  1. Use a new encoder cable and connect wirings correctly. Then rotate motor shaft manually and check whether the fault persists.
  2. Rotate motor shaft manually and check whether the fault persists.
