Basics of Foot valves, Types of foot valves
Foot valves are check valves designed to be installed at the bottom of suction lines to prevent the backflow of fluid (usually liquid) when the pump is not in operation. They are commonly used in applications such as water wells, irrigation systems, sump pumps, and firefighting systems. Foot valves work by allowing fluid to flow into the suction line when the pump is operating, but they close automatically when the pump stops to prevent reverse flow and maintain prime.
Key characteristics and types of foot valves include:
  1. Basic Design:
    • Foot valves typically consist of a body (often made of cast iron, brass, or stainless steel), a cover, a sealing element (such as a rubber disc or flapper), and a strainer or screen to prevent debris from entering the pump.
    • The valve is installed at the end of the suction pipe, with the intake opening submerged in the fluid to be pumped. When the pump is activated, the fluid enters the valve, lifting the sealing element and allowing flow. When the pump stops, the sealing element returns to the closed position, preventing backflow.
  2. Types of Foot Valves:
    • Flapper Foot Valve: This type of foot valve uses a flexible rubber or plastic flapper as the sealing element. The flapper lifts when fluid flows into the suction line and closes under its own weight when the flow stops.
    • Ball Foot Valve: Ball foot valves have a spherical or cylindrical ball as the sealing element. When fluid flows into the suction line, the ball is lifted, allowing flow. When the flow stops, the ball settles back into the seat, sealing the valve.
    • Spring-Loaded Foot Valve: Spring-loaded foot valves incorporate a spring mechanism to assist in closing the valve when the flow stops. The spring helps ensure a positive seal and prevents leakage.
    • Wafer-Style Foot Valve: Wafer-style foot valves are compact and lightweight, designed for use in applications where space is limited. They feature a low-profile design and are often used in shallow wells or tight spaces.
  3. Material of Construction:
    • Foot valves are available in various materials of construction, including cast iron, brass, bronze, stainless steel, PVC (polyvinyl chloride), and thermoplastics. The choice of material depends on factors such as fluid compatibility, corrosion resistance, and application requirements.
  4. Screen or Strainer:
    • Many foot valves are equipped with a built-in screen or strainer at the inlet to prevent the entry of debris, rocks, or other solid particles into the pump. The screen or strainer helps protect the pump from damage and ensures uninterrupted flow.
Overall, foot valves are essential components in suction piping systems, ensuring reliable operation and preventing damage to pumps by maintaining prime and preventing backflow. The selection of the appropriate type and size of foot valve depends on factors such as the application, fluid characteristics, flow rate, and system requirements.
