Basics of Pitot tube
A Pitot tube is a device used to measure fluid flow velocity in a pipe or duct. It operates based on the principles of fluid dynamics and Bernoulli's equation. Here are the basics of a Pitot tube:
  1. Design: A Pitot tube consists of a slender tube with two openings (ports) at different positions along its length. One opening, known as the stagnation port or impact port, faces directly into the fluid flow, while the other opening is positioned perpendicular to the flow direction and is used to measure static pressure.
  2. Stagnation Pressure: When fluid flows into the stagnation port, it comes to a stop, creating a stagnation point where the fluid velocity is zero. At this point, the pressure is at its highest value, known as the stagnation pressure or total pressure. This pressure represents the sum of the static pressure (due to fluid weight) and the dynamic pressure (due to fluid velocity).
  3. Static Pressure: The static pressure is the pressure exerted by the fluid perpendicular to the direction of flow. It is measured at the opening perpendicular to the flow direction. The static pressure represents the pressure of the fluid when it is not in motion and is influenced by factors such as fluid density and gravitational forces.
  4. Velocity Calculation: The difference between the stagnation pressure and the static pressure, known as the dynamic pressure, is directly related to the velocity of the fluid.
  1. Applications: Pitot tubes are commonly used in various industries and applications to measure fluid flow velocity. They are used in aircraft to measure airspeed, in HVAC systems to measure air velocity, in fluid mechanics experiments, and in industrial processes for flow monitoring and control.
  2. Installation: Proper installation of the Pitot tube is crucial for accurate flow velocity measurement. The tube should be positioned at the centerline of the flow, with the stagnation port facing directly into the flow stream. Adequate straight pipe lengths upstream and downstream of the tube are necessary to ensure fully developed flow conditions and accurate measurement.
Overall, Pitot tubes provide a simple and cost-effective method for measuring fluid flow velocity based on the principles of fluid dynamics and Bernoulli's equation. They are widely used in various applications where accurate flow velocity measurement is required.
