A "bonded strain gauge" is a type of transducer used to measure strain (deformation) in materials. It operates based on the principle of piezoresistivity, where the electrical resistance of a material changes when subjected to mechanical stress. These strain gauges are directly attached or bonded to the surface of the structure under study. Let’s dive into the details:
1. Construction and Working Principle:
- A bonded strain gauge consists of a fine resistance wire (usually made of materials like nichrome, constantan, or nickel) bonded or pasted onto a thin, flexible substrate (such as paper, tissue, Bakelite, or Teflon).
- The substrate acts as a carrier, and the gauge wire is directly attached to the surface of the structure.
- When the structure experiences stress or strain (due to forces, pressure, or deformation), the gauge wire also undergoes changes in length and cross-section.
- As a result, the electrical resistance of the gauge wire changes proportionally to the applied strain.
2. Types of Bonded Strain Gauges:
Bonded strain gauges are further divided into three main types:
Wire Type Strain Gauge:
- Available in both bonded and unbonded configurations.
- In the bonded type, the strain gauge is directly pasted onto the surface of the structure under test using adhesives.
- Adhesives transmit strain from the structure to the gauge wires.
- Varieties include:
- Flat grid wire gauge
- Wrap-around wire gauge
- Single wire gauge
- Woven type gauge
Foil Type Strain Gauge:
- Composed of metallic foil (usually made of materials like constantan or nickel) bonded to a flexible insulating carrier.
- Foil strain gauges are widely used due to their versatility and accuracy.
- They exhibit excellent linearity and sensitivity.
Semiconductor Strain Gauge:
- Utilizes semiconductor materials (such as silicon) with piezoresistive properties.
- These gauges are sensitive to temperature changes and can be integrated into microelectronic circuits.
3. Advantages and Applications:
- Advantages:
- Greater accuracy compared to other strain gauge types.
- Suitable for a wide range of strain measurements.
- Can be used in the range of ±0.15% strain.
- Applications:
- Measurement of pressure, acceleration, and force.
- Used in systems where gauges need placement at different locations and frequent stress or pressure measurements.
