Burkert Valve Error Codes
Burkert valves are widely used in various industries for fluid control applications. "Burkert Valve Error Codes" indicate an error occur in valve due to internal problem or external conditions. While the specific error codes may vary depending on the model and type of valve, here are some common error codes you might encounter:
Error Code
Explanation
Cause
Solution
2001
Valve closing failed
- Residual pressure in the valve.
- Valve contamination.
- Valve damage.
- Check and relieve pressure.
- Clean the valve.
- Replace the valve.
2002
Valve does not open
- Insufficient pressure in the valve.
- Valve damage.
- Check the pressure.
- Clean the valve.
2003
Position sensor error
- Sensor malfunction.
- Sensor cable damage.
- Check the sensor.
- Replace the sensor.
2004
Valve overheating
- Excessively high ambient temperature.
- Insufficient valve cooling.
- Reduce the ambient temperature.
- Improve valve cooling.
2005
Coil short circuit
- Coil damage.
- Replace the coil.
2006
Coil open circuit
- Coil damage.
- Replace the coil.
2007
Low supply voltage
- Insufficient supply voltage.
- Check the supply voltage.
2008
Overvoltage
- Excessive supply voltage.
3001
- Valve not fully closed.
- Check the valve.
3002
- Low system pressure.
- Check the system pressure.
3003
Valve leakage
- Valve damage.
3004
Pressure sensor error
- Check the sensor.
4001
Communication error with the control module
- Communication cable damage.
- Control module malfunction.
- Check the cable.
- Replace the control module.
4002
Incorrect configuration of the control module
- Incorrect configuration parameters.
- Check the configuration parameters.
4003
Control module software error
- Software malfunction.
- Update the software.
5001
General error
- Unknown cause.
- Contact the service center.
5002
Unknown error
- Unknown cause.
Burkert Pneumatic Valves Common Error Codes:
The error codes that occur most often in pneumatic valve will help you quickly determine the cause of the error and take appropriate measures to eliminate it.
Error Code Description Error Causes Troubleshooting Tips
E01 Sensor error
- Faulty valve position sensor
- Faulty pressure sensor
E02 Pressure too high - Excessive inlet pressure - Check inlet pressure
E03 Pressure too low
- Low inlet pressure
- Leak in the valve
- Check the valve for leaks
E04 Delay in operation
- Faulty valve
- Check the valve
- Clean the valve
E05 Communication error
- Communication error with PLC
- Cable damage
- Check the communication cable
- Replace the communication cable
E06 Overheating - Excessive coil temperature
- Check coil temperature
- Replace coil
E07 Short circuit - Short circuit in the coil - Replace coil
Other Control Valve Error Code:
The table below describes the other error codes that may occur in Burkert control valves:
Error Code Description Possible Causes Troubleshooting Tips
E01 Temperature too high
- High ambient temperature
- Faulty temperature sensor
- Check ambient temperature
- Replace temperature sensor
E02 Temperature too low
- Low ambient temperature
E03 Pressure too high
- Valve clogged
- Clean the valve
E04 Pressure too low
- Leak in the valve
E05 Sensor error
E06 Communication error
- Cable damage
E07 Overheating - Excessive coil temperature
- Replace coil
E08 Short circuit - Short circuit in the coil - Replace coil
It's important to consult the specific user manual or documentation for your Burkert valve model to determine the exact meaning of error codes and troubleshooting steps. Additionally, contacting Burkert technical support or consulting with a qualified technician can help diagnose and resolve any issues with the valve.
