Check valves - types
Check valves, also known as non-return valves or one-way valves, are designed to allow fluid flow in one direction while preventing reverse flow. There are several types of check valves, each with its own design and applications. Here are some common types of check valves:
  1. Swing Check Valve:
    • Swing check valves have a hinged disc or flap that swings open in the direction of flow and closes under the influence of gravity or backflow pressure to prevent reverse flow.
    • They are commonly used in applications where low pressure drop and unobstructed flow are required, such as wastewater systems, HVAC systems, and water supply lines.
  2. Lift Check Valve:
    • Lift check valves have a disc or piston that lifts vertically off the seat to allow forward flow and closes under the weight of the disc or pressure differential to prevent backflow.
    • They are suitable for high-pressure applications and are often used in steam systems, boiler feedwater lines, and power generation plants.
  3. Spring Check Valve:
    • Spring check valves use a spring-loaded disc or piston that is held against the seat to prevent backflow. When forward flow occurs, the pressure pushes the disc or piston open against the spring force.
    • They are commonly used in applications where reliable sealing and positive closure are required, such as pumps, compressors, and hydraulic systems.
  4. Ball Check Valve:
    • Ball check valves use a spherical ball as the closing mechanism to prevent backflow. When forward flow occurs, the ball is pushed away from the seat, allowing fluid to pass through. When flow stops or reverses, the ball returns to its seat, preventing backflow.
    • They are suitable for applications requiring low friction and minimal pressure drop, such as fuel lines, irrigation systems, and chemical processing.
  5. Dual Plate Check Valve:
    • Dual plate check valves have two spring-loaded plates that swing open in the direction of flow and close under reverse flow conditions.
    • They offer reduced weight and size compared to traditional swing check valves and are commonly used in applications where space and weight are limited, such as offshore drilling platforms, oil refineries, and marine applications.
  6. Diaphragm Check Valve:
    • Diaphragm check valves use a flexible diaphragm or membrane as the sealing element to prevent backflow. When forward flow occurs, the diaphragm flexes away from the seat, allowing fluid to pass through. When flow stops or reverses, the diaphragm returns to its seat, preventing backflow.
    • They are commonly used in applications requiring high purity and cleanliness, such as pharmaceutical, food and beverage, and semiconductor manufacturing.
These are some of the common types of check valves used in various industries and applications. The selection of the appropriate type depends on factors such as flow rate, pressure, temperature, fluid properties, and application requirements.
