Control Valve Classification
Control valves are classified based on various factors such as their method of operation, function, construction, and application. Here are some common classifications of control valves:
  1. Based on Method of Operation:
    • Manual Valves: These valves are operated manually by a person using a handwheel, lever, or similar mechanism.
    • Automatic Valves: These valves are operated automatically by an external signal or control system, such as pneumatic, hydraulic, or electric actuators.
  2. Based on Function:
    • On/Off Valves: Also known as isolation valves, these valves are used to fully open or fully close the flow path.
    • Throttling Valves: These valves are used to regulate the flow rate or pressure within a system by partially opening or closing the valve.
  3. Based on Construction:
    • Globe Valves: These valves have a globe-shaped body and linear motion mechanism for opening and closing the flow path.
    • Butterfly Valves: These valves have a disc-shaped closure element that rotates about a central axis to control flow.
    • Ball Valves: These valves have a spherical closure element (ball) that rotates to open or close the flow path.
    • Plug Valves: These valves have a cylindrical or tapered plug that moves linearly to control flow.
    • Diaphragm Valves: These valves use a flexible diaphragm as the closure element, which flexes to control flow.
    • Pinch Valves: These valves use a flexible tube (or sleeve) that is pinched to control flow.
  4. Based on Actuation Type:
    • Pneumatic Valves: These valves are actuated using compressed air or gas.
    • Hydraulic Valves: These valves are actuated using hydraulic fluid.
    • Electric Valves: These valves are actuated using electrical power.
    • Manual Valves: These valves are operated manually by hand.
  5. Based on Valve Characteristic:
    • Linear Valves: These valves have a linear relationship between the valve position and flow rate.
    • Equal Percentage Valves: These valves provide an equal percentage change in flow rate for a given change in valve position.
    • Quick Opening Valves: These valves provide a large change in flow rate for a small change in valve position at the beginning of the valve stroke.
  6. Based on Application:
    • Control Valves: These valves are specifically designed for controlling flow, pressure, or temperature in a process system.
    • Safety Valves: These valves are used to protect equipment or systems from overpressure conditions.
    • Relief Valves: These valves are used to relieve excess pressure from a system to prevent damage or failure.
These classifications help in selecting the appropriate control valve for a given application based on its intended function, operating conditions, and control requirements.
