Diaphragm seal pressure transmitters
Diaphragm seal pressure transmitters, also known as diaphragm seal systems or remote diaphragm seals, are specialized pressure measurement devices used in applications where the process fluid is corrosive, viscous, contains particulates, or operates at extreme temperatures. These transmitters incorporate a diaphragm seal to isolate the sensitive pressure sensing element from the process fluid, thus protecting it from damage and ensuring accurate and reliable pressure measurement. Here's an overview of diaphragm seal pressure transmitters:
  1. Operating Principle:
    • Diaphragm seal pressure transmitters operate based on the principle of transmitting pressure from the process fluid to the pressure sensing element (e.g., piezoresistive or capacitive) through a flexible diaphragm.
    • The diaphragm separates the process fluid from the sensing element, preventing direct contact and potential damage to the sensing element.
    • Pressure applied to the diaphragm deforms it, causing a corresponding change in pressure within the sealed chamber connected to the sensing element.
  2. Components:
    • Diaphragm Seal: The diaphragm seal is the primary component that separates the process fluid from the sensing element. It is typically made of corrosion-resistant materials such as stainless steel, Hastelloy, or PTFE.
    • Fill Fluid: The sealed chamber behind the diaphragm may be filled with a fill fluid (e.g., silicone oil, glycerin) to transmit pressure to the sensing element and enhance response time and accuracy.
    • Pressure Sensing Element: The pressure sensing element converts the pressure transmitted through the diaphragm into an electrical signal (e.g., voltage or current) proportional to the applied pressure.
    • Transmitter Housing: The transmitter housing contains the electronic circuitry necessary for signal processing, amplification, and output signal conditioning.
  3. Advantages:
    • Protection: Diaphragm seal pressure transmitters protect the sensitive pressure sensing element from exposure to corrosive, abrasive, or high-temperature process fluids, extending the sensor's lifespan and reliability.
    • Versatility: They are suitable for a wide range of industrial applications, including chemical processing, pharmaceuticals, food and beverage, pulp and paper, and wastewater treatment.
    • Accuracy: By isolating the sensing element from the process fluid, diaphragm seal pressure transmitters offer high accuracy and stability in pressure measurement, even in harsh operating conditions.
    • Flexibility: Diaphragm seal systems offer flexibility in selecting diaphragm materials, fill fluids, and transmitter configurations to suit specific application requirements.
  4. Applications:
    • Chemical Processing: Diaphragm seal pressure transmitters are commonly used in chemical plants for measuring pressures of corrosive fluids and gases.
    • Food and Beverage: They find applications in food processing and beverage production for measuring pressures of viscous or abrasive media.
    • Pharmaceuticals: Diaphragm seal systems are utilized in pharmaceutical manufacturing processes where precise pressure measurement is critical for quality control.
    • Pulp and Paper: They are employed in pulp and paper mills for monitoring pressures in pulp digester vessels, paper machines, and chemical recovery processes.
    • Wastewater Treatment: Diaphragm seal pressure transmitters are used in wastewater treatment plants for measuring pressures in sewage systems, filtration processes, and sludge handling equipment.
  5. Considerations:
    • Selection of Diaphragm Material: The choice of diaphragm material should consider the compatibility with the process fluid to prevent chemical reactions or contamination.
    • Fill Fluid Selection: The selection of fill fluid should consider factors such as temperature range, viscosity, and compatibility with the process fluid.
    • Installation and Maintenance: Proper installation and periodic maintenance of diaphragm seal pressure transmitters are essential to ensure reliable performance and accuracy over time.
In summary, diaphragm seal pressure transmitters offer a robust solution for accurate and reliable pressure measurement in challenging industrial environments where process fluids may be corrosive, abrasive, or at extreme temperatures. By providing isolation and protection to the sensing element, diaphragm seal systems ensure long-term performance and durability in demanding applications.
