Difference between bonded and Unbonded Strain Gauge?
Bonded and unbonded strain gauges are two types of strain gauges used for measuring mechanical strain in structures or materials. They differ primarily in their installation method and the way they respond to strain. Here's a comparison between bonded and unbonded strain gauges:
  1. Installation Method:
    • Bonded Strain Gauges: Bonded strain gauges are affixed directly to the surface of the material or structure being tested using a special adhesive or bonding agent. The gauge is bonded to the material's surface with its grid pattern aligned with the direction of expected strain.
    • Unbonded Strain Gauges: Unbonded strain gauges are not directly attached to the surface of the material. Instead, they are installed within a protective housing or carrier, which is then mounted onto the material's surface using mechanical fixtures. The carrier provides protection to the gauge and allows for easy removal and replacement.
  2. Response to Strain:
    • Bonded Strain Gauges: Bonded strain gauges directly adhere to the material's surface, making them more sensitive to surface strains. They measure strains at the exact point where they are applied, providing precise localized strain measurements.
    • Unbonded Strain Gauges: Unbonded strain gauges are mounted onto the material's surface but are not directly bonded to it. As a result, they are less sensitive to surface strains and may measure strains from a larger area of the material. They are better suited for measuring average or global strains across a larger section of the material.
  3. Durability and Longevity:
    • Bonded Strain Gauges: Bonded strain gauges are directly exposed to the surface conditions of the material, which can impact their durability and longevity. Factors such as adhesion quality, temperature variations, and environmental conditions can affect the performance and lifespan of bonded strain gauges.
    • Unbonded Strain Gauges: Unbonded strain gauges are typically more protected from environmental factors due to their housing or carrier. This can result in better durability and longer lifespan compared to bonded strain gauges. Additionally, unbonded strain gauges can be easily removed and replaced without damaging the material's surface.
  4. Cost and Complexity:
    • Bonded Strain Gauges: Bonded strain gauges are generally less expensive and simpler to install compared to unbonded strain gauges. They require less equipment and expertise for installation but may require more care and attention to ensure proper bonding and alignment.
    • Unbonded Strain Gauges: Unbonded strain gauges may be more expensive and complex due to the additional housing or carrier required for installation. However, they offer advantages in terms of flexibility, ease of replacement, and protection from surface conditions.
In summary, the choice between bonded and unbonded strain gauges depends on factors such as the specific application requirements, desired level of sensitivity, durability considerations, and budget constraints. Each type has its advantages and limitations, and the selection should be based on a careful evaluation of these factors.
