Flow measurement using Hot wire anemometers
Hot wire anemometers are instruments used to measure the velocity of a fluid flow, typically air, based on the cooling effect of the fluid on a heated wire. Here's how flow measurement using a hot wire anemometer typically works:
  1. Principle of Operation: Hot wire anemometers operate based on the principle of convective heat transfer. A thin wire, typically made of tungsten or platinum, is heated to a constant temperature using an electric current. As the fluid flows over the wire, it removes heat from the wire due to convective cooling, causing a change in the wire's resistance.
  2. Measurement of Cooling Effect: The cooling effect of the fluid flow on the heated wire is directly proportional to the velocity of the fluid. Higher flow velocities result in greater convective cooling and a larger change in the wire's resistance.
  3. Bridge Circuit and Signal Processing: The change in resistance of the heated wire is measured using a Wheatstone bridge circuit. This circuit compares the resistance of the wire with that of a reference resistor and produces an output voltage proportional to the flow velocity. The output voltage is then processed and converted into a digital or analog signal for display or further analysis.
  4. Calibration: Prior to use, hot wire anemometers are calibrated to establish a linear relationship between the flow velocity and the output signal. Calibration ensures accurate and reliable velocity measurements over a specified range of flow velocities and operating conditions.
  5. Probe Design and Configuration: Hot wire anemometers can be configured in various probe designs, including single wire, two-wire, and three-wire configurations. Single wire configurations are simpler and less sensitive to flow direction, while two- and three-wire configurations offer higher sensitivity and accuracy.
  6. Applications: Hot wire anemometers are commonly used for measuring air velocity and flow in a wide range of applications, including HVAC systems, environmental monitoring, aerodynamics research, and industrial ventilation. They are particularly well-suited for low-velocity airflow measurements and turbulent flow conditions.
  7. Installation and Usage: When using a hot wire anemometer for flow measurement, the probe should be positioned perpendicular to the flow direction and inserted into the airflow at the measurement location. Care should be taken to ensure that the probe is not obstructed by obstacles or structures in the flow path, which could affect the accuracy of the measurements.
  8. Considerations: Hot wire anemometers are sensitive instruments and may be affected by factors such as temperature variations, humidity, and vibrations. Proper calibration, maintenance, and use in controlled environmental conditions are important to ensure accurate and reliable measurements.
Overall, hot wire anemometers offer a versatile and precise method for measuring fluid flow velocities, particularly in low-velocity airflow and turbulent flow conditions. Their compact size, high sensitivity, and fast response time make them valuable tools for a wide range of flow measurement applications.
