Function of a hair–spring in a pressure gauge
In a pressure gauge, the hair-spring serves as the mechanism that translates the deflection of the sensing element (such as a diaphragm or Bourdon tube) into a readable indication on the gauge's dial. Here's how the hair-spring functions in a pressure gauge:
  1. Connection to Sensing Element: The hair-spring is typically attached to the moving part of the sensing element, such as the tip of a Bourdon tube or the center of a diaphragm. When pressure is applied to the sensing element, it deforms, causing the hair-spring to move.
  2. Spring Tension: The hair-spring is designed to exert a specific amount of tension or force on the sensing element in its neutral position (i.e., when there is no pressure applied). This tension acts as a reference point for the gauge's zero reading.
  3. Deflection: As pressure is applied to the sensing element, it deflects from its neutral position. The hair-spring moves along with the sensing element, resisting the deflection to some extent due to its tension.
  4. Dial Movement: The movement of the hair-spring is transmitted to the gauge's dial mechanism, typically through a linkage system or gears. This movement causes the pointer on the dial to rotate, indicating the pressure being measured.
  5. Scale Calibration: The tension of the hair-spring is calibrated during the manufacturing process to ensure accurate pressure readings. By adjusting the tension of the hair-spring, the gauge can be calibrated to display pressure readings within a specific range.
  6. Zero Adjustment: Some pressure gauges feature a zero-adjustment screw or knob connected to the hair-spring mechanism. This allows for fine-tuning of the zero reading to compensate for any offset or drift in the gauge's calibration.
In summary, the hair-spring in a pressure gauge serves as a crucial component for translating the mechanical deformation of the sensing element into a readable pressure indication on the gauge's dial. It provides the necessary tension and reference point for accurate pressure measurements and allows for calibration adjustments to maintain the gauge's accuracy over time.
