How Coriolis mass flowmeter works?
A Coriolis mass flow meter operates based on the principle of Coriolis effect, which is a phenomenon observed in rotating systems where a moving object experiences a force perpendicular to its direction of motion. In the case of a Coriolis mass flow meter, this effect is utilized to measure the mass flow rate of fluids passing through the meter. Here's how it works:
  1. Vibration Generation: The core component of a Coriolis mass flow meter is a U-shaped or straight tube made of a dense and rigid material such as stainless steel. This tube is typically mounted to the meter housing via vibration sensors or coils.
  2. Fluid Flow: When fluid flows through the tube, it causes the tube to vibrate or oscillate at a specific resonant frequency. This vibration is typically induced by electromechanical means such as piezoelectric elements or electromagnetic coils located at the base of the tube.
  3. Coriolis Effect: As the fluid flows through the vibrating tube, it experiences inertial forces due to the Coriolis effect. When the tube oscillates, it undergoes slight bending or twisting motions perpendicular to the direction of fluid flow.
  4. Phase Shift Detection: The Coriolis effect causes a phase shift between the vibration of the inlet and outlet sections of the tube. This phase shift is directly proportional to the mass flow rate of the fluid passing through the tube.
  5. Measurement: Sensors located at the inlet and outlet sections of the tube detect the phase shift between the vibrations. By measuring this phase shift, the Coriolis mass flow meter calculates the mass flow rate of the fluid in real-time.
  6. Output Signal: The Coriolis mass flow meter typically provides an output signal proportional to the mass flow rate, which can be in the form of an analog signal (e.g., 4-20 mA) or digital communication protocols (e.g., HART, Modbus).
  7. Temperature and Density Compensation: To ensure accurate measurement, Coriolis mass flow meters often incorporate temperature and density sensors to compensate for changes in fluid properties such as viscosity and density.
  8. Installation Considerations: Proper installation of Coriolis mass flow meters is crucial for accurate measurement. This includes ensuring that the meter is installed in a vertical or horizontal orientation, with sufficient straight pipe lengths upstream and downstream to allow for fully developed flow profiles.
Overall, Coriolis mass flow meters provide highly accurate and reliable measurement of mass flow rates across a wide range of fluid types and operating conditions. They are widely used in industries such as oil and gas, chemical processing, food and beverage, and pharmaceuticals for various process control and monitoring applications.
