How displacer level gauge works?
A displacer level gauge is a type of level measurement instrument used to determine the level of liquid in a vessel. It operates based on the principle of buoyancy, similar to how a ship floats on water. Here's how it works:
  1. Displacer Installation: The displacer is a buoyant object typically made of a material with a specific gravity greater than that of the liquid being measured. It is attached to a suspension cable or rod, which is connected to the top of the vessel. The displacer is partially submerged in the liquid, with the remainder of it extending above the liquid surface.
  2. Buoyancy Principle: According to Archimedes' principle, an object submerged in a fluid experiences an upward buoyant force equal to the weight of the fluid displaced by the object. In the case of the displacer, this buoyant force depends on the volume of the displacer submerged in the liquid, which in turn depends on the level of the liquid.
  3. Force Measurement: As the liquid level changes, the buoyant force acting on the displacer changes accordingly. The displacer is connected to a force measurement mechanism, such as a spring or a load cell, which measures the tension or compression force exerted on it due to the buoyant force.
  4. Output Signal: The force measurement mechanism converts the tension or compression force into an electrical signal. This signal is typically proportional to the level of the liquid in the vessel.
  5. Calibration: Before use, the displacer level gauge needs to be calibrated to establish a relationship between the measured force (or electrical signal) and the corresponding liquid level. This calibration accounts for factors such as the specific gravity of the displacer, the length of the suspension cable or rod, and any other relevant parameters.
  6. Output Display: The electrical signal generated by the displacer level gauge can be sent to a display device, control system, or data acquisition system for further processing or monitoring. This signal provides real-time information about the level of the liquid in the vessel.
Displacer level gauges are commonly used in various industries due to their reliability, accuracy, and suitability for measuring the level of liquids in vessels under different operating conditions. They are particularly well-suited for applications involving corrosive, high-temperature, or high-pressure liquids.
