How does a Infrared Thermometer(IRT) works?
Infrared thermometers (IRTs), also known as infrared pyrometers or infrared thermometers, are devices used to measure temperature without direct contact with the object being measured. They work based on the principle of detecting thermal radiation emitted by an object and converting it into a temperature reading. Here's how an infrared thermometer typically works:
  1. Infrared Sensor: The core component of an infrared thermometer is an infrared sensor, often referred to as a detector. This sensor is designed to detect and measure thermal radiation emitted by objects in the form of infrared light.
  2. Optics: Infrared thermometers are equipped with optics, such as lenses or mirrors, to focus the thermal radiation emitted by the object onto the infrared sensor. The optics help to collect and concentrate the infrared energy onto the sensor, improving the accuracy and sensitivity of temperature measurements.
  3. Detection and Measurement: When the infrared radiation from the object reaches the sensor, it is absorbed, and the sensor generates an electrical signal proportional to the intensity of the infrared radiation. This signal is then processed by electronic circuitry within the thermometer.
  4. Temperature Calculation: The electronic circuitry processes the electrical signal from the sensor and calculates the temperature of the object based on the intensity of the detected infrared radiation. This calculation typically involves comparing the detected radiation to a known reference signal or calibration curve to determine the temperature.
  5. Display: The calculated temperature is then displayed on a digital screen or analog scale, allowing the user to read the temperature measurement directly.
  6. Emissivity Adjustment: Some infrared thermometers allow the user to adjust the emissivity setting to account for variations in the surface emissivity of different materials. Emissivity is a measure of how effectively an object emits thermal radiation, and adjusting the emissivity setting ensures accurate temperature measurements across various materials and surfaces.
  7. Distance-to-Spot Ratio: Infrared thermometers often have a distance-to-spot ratio specification, indicating the ratio of the distance from the thermometer to the object (the spot size) to the diameter of the measurement area. This specification determines the size of the measurement area and the accuracy of temperature readings at different distances from the object.
Overall, infrared thermometers provide a non-contact method for accurately measuring temperature, making them suitable for a wide range of applications in industries such as manufacturing, automotive, food processing, HVAC, and medical diagnostics.
