How level is measured using Differential pressure transmitter?
A differential pressure (DP) transmitter is commonly used to measure level in industrial processes. It operates based on the principle that as the level of a liquid or material increases or decreases in a vessel, it exerts pressure on the bottom of the vessel. This pressure is directly proportional to the height (or depth) of the liquid or material.
Here's how a DP transmitter measures level:
  1. Installation: The DP transmitter is installed such that the pressure-sensing diaphragms or ports are positioned at different elevations. One port is placed at the bottom of the vessel (where the pressure from the liquid or material is exerted), and the other port is typically located at the top of the vessel or connected to a reference pressure, such as atmospheric pressure.
  2. Pressure Measurement: The DP transmitter measures the difference in pressure between the two ports. This difference is directly related to the level of the liquid or material in the vessel. The transmitter typically contains a pressure sensor (such as a strain gauge) that converts the pressure difference into an electrical signal.
  3. Calibration: Before use, the DP transmitter needs to be calibrated to convert the electrical signal into a corresponding level measurement. This calibration process involves setting the transmitter's range and adjusting it to match the specific characteristics of the vessel and the material being measured.
  4. Output: The DP transmitter provides an output signal (typically in milliamps, such as 4-20 mA) that corresponds to the measured level. This signal can be sent to a control system, data acquisition system, or display device for further processing or monitoring.
  5. Compensation: It's important to compensate for factors such as variations in temperature, density of the liquid or material, and atmospheric pressure changes to ensure accurate level measurements over time.
By measuring the pressure difference between two points, the DP transmitter effectively calculates the level of the substance in the vessel. This method is widely used due to its reliability, accuracy, and suitability for various industrial applications.
