How to calibrate pressure gauge? Using Dead weight Tester
Calibrating a pressure gauge using a deadweight tester involves applying known pressures to the gauge and comparing the indicated readings with the actual applied pressures. Here's a step-by-step guide on how to calibrate a pressure gauge using a deadweight tester:
  1. Prepare the Equipment:
    • Ensure that the deadweight tester and pressure gauge are clean and free from any debris or contaminants.
    • Verify that the deadweight tester is properly calibrated and traceable to national or international standards.
  2. Select Test Points:
    • Determine the range of pressures over which you want to calibrate the pressure gauge.
    • Select several test points within this range, including minimum, maximum, and intermediate pressures.
  3. Set Up the Deadweight Tester:
    • Install the appropriate weights on the piston assembly of the deadweight tester to generate the desired test pressures.
    • Ensure that the deadweight tester is securely mounted on a stable surface and that the piston assembly moves freely without any obstructions.
  4. Apply Pressure:
    • Apply the first test pressure to the pressure gauge using the deadweight tester.
    • Allow sufficient time for the pressure reading on the gauge to stabilize.
  5. Record Readings:
    • Record the indicated pressure reading on the gauge.
    • Take multiple readings at each test pressure to account for any fluctuations or drift in the gauge's response.
  6. Adjustment (if Necessary):
    • If the indicated readings deviate from the applied pressures, make any necessary adjustments to the pressure gauge.
    • Some pressure gauges may have adjustment screws or mechanisms to fine-tune the readings.
  7. Repeat Steps:
    • Repeat the process for each selected test pressure, applying and recording the readings at each point.
    • Ensure that the deadweight tester is reconfigured to generate the appropriate test pressures for each step.
  8. Evaluate Calibration:
    • Compare the recorded readings of the pressure gauge with the applied pressures from the deadweight tester.
    • Calculate the error or deviation between the indicated readings and the actual pressures at each test point.
    • Evaluate the overall accuracy and performance of the pressure gauge across its calibrated range.
  9. Document Results:
    • Document the calibration results, including the applied pressures, indicated readings, and any adjustments made to the pressure gauge.
    • Prepare a calibration certificate or report detailing the calibration process and results for future reference.
  10. Verify Traceability:
    • Ensure that the calibration process is performed in accordance with applicable standards and regulations.
    • Verify the traceability of the calibration to national or international standards by using calibrated reference equipment and following established procedures.
By following these steps carefully, you can calibrate a pressure gauge using a deadweight tester accurately and effectively, ensuring reliable pressure measurements in your applications.
