How to decide LRV and URV of Flow transmitter (differential pressure transmitter)?
LRV (Lower Range Value) and URV (Upper Range Value) are important parameters to set when configuring a differential pressure (DP) transmitter for flow measurement. Here's how to decide on the appropriate LRV and URV values:
  1. Understand the Measurement Range:
    • Determine the expected range of differential pressures that the transmitter will measure. This range should cover the normal operating conditions of the process, including variations in flow rates.
  2. Consider Operating Conditions:
    • Take into account the minimum and maximum expected flow rates in the process. This will help determine the range of differential pressures that the transmitter will need to measure.
  3. Calculate Differential Pressure Range:
    • Calculate the differential pressure range based on the expected flow rates and the characteristics of the flow element (e.g., orifice plate, venturi tube) installed in the pipeline. The differential pressure range is typically defined as the maximum differential pressure minus the minimum differential pressure.
  4. Select LRV and URV:
    • Choose the LRV and URV values based on the calculated differential pressure range.
    • LRV: Set the LRV value to correspond to the minimum expected differential pressure in the process. This ensures that the transmitter can accurately measure low flow rates without saturating the signal.
    • URV: Set the URV value to correspond to the maximum expected differential pressure in the process. This ensures that the transmitter can accurately measure high flow rates without exceeding its measurement range.
  5. Margin and Safety Factor:
    • It's common practice to add a margin or safety factor to the LRV and URV values to accommodate any unexpected variations or transient conditions in the process. The margin should be sufficient to prevent the transmitter from reaching its limits under normal operating conditions.
  6. Consider Transmitter Specifications:
    • Take into account the specifications and limitations of the DP transmitter, including its measurement range, accuracy, and overload capabilities. Ensure that the selected LRV and URV values are within the transmitter's operating range.
  7. Consult Standards and Guidelines:
    • Refer to industry standards, guidelines, or recommendations specific to your application or process industry. These resources may provide additional guidance on selecting appropriate LRV and URV values for flow measurement applications.
  8. Configure Transmitter:
    • Once the LRV and URV values have been determined, configure the DP transmitter accordingly using the manufacturer's configuration software or interface. Enter the LRV and URV values into the transmitter's configuration parameters.
  9. Calibration and Verification:
    • After configuring the transmitter, perform calibration and verification procedures to ensure that it accurately measures differential pressures within the specified range. Adjust the transmitter if necessary to achieve the desired performance.
By carefully selecting and configuring the LRV and URV values for the DP transmitter, you can ensure accurate and reliable flow measurement in your process. Regular maintenance and calibration are essential to maintain optimal performance over time.
