How to measure level using Load cell? | Open tank level measurement?
Measuring the level of a liquid in an open tank using a load cell involves indirectly determining the liquid level by measuring the weight or mass of the liquid. Here's a general overview of how to measure the level using a load cell in an open tank:
  1. Mounting the Load Cell:
    • Begin by mounting the load cell securely underneath the tank. The load cell should be positioned to support the weight of the tank and its contents. Ensure that the load cell is properly calibrated and rated to handle the maximum weight of the liquid in the tank.
  2. Attaching the Tank to the Load Cell:
    • Connect the tank to the load cell in a manner that allows the load cell to accurately measure the weight of the liquid. This may involve using load cell mounting hardware or brackets to attach the tank securely to the load cell.
  3. Calibration:
    • Calibrate the load cell to accurately measure the weight or mass of the liquid in the tank. This typically involves applying known weights to the load cell and adjusting the calibration settings until the load cell provides accurate readings.
  4. Measuring the Level:
    • As the level of the liquid in the tank changes, the weight or mass of the liquid resting on the load cell will also change. The load cell will measure this change in weight and provide an output signal proportional to the liquid level.
  5. Conversion to Level Measurement:
    • Convert the output signal from the load cell into a measurement of liquid level. This may involve using calibration curves or mathematical formulas to relate the weight or mass measured by the load cell to the corresponding liquid level.
  6. Data Acquisition and Display:
    • Connect the load cell output to a data acquisition system or controller that can process the signal and display the liquid level measurement. This system may include digital displays, data loggers, or computer interfaces for monitoring and recording the level data.
  7. Considerations for Open Tanks:
    • In open tank level measurement applications, it's important to account for factors such as changes in atmospheric pressure, temperature variations, and the density of the liquid. These factors can affect the accuracy of the level measurement and may require additional compensation or correction methods.
By following these steps and considering the specific requirements of your application, you can effectively measure the level of a liquid in an open tank using a load cell.
