How to measure pressure using McLeod gauge?
Measuring pressure using a McLeod gauge involves a series of steps to create a vacuum within a sealed volume and then measure the pressure by determining the volume of gas captured at the desired pressure. Here's a general procedure for measuring pressure using a McLeod gauge:
  1. Preparation:
    • Ensure the McLeod gauge is clean and free from any contaminants.
    • Connect the McLeod gauge to a vacuum pump capable of achieving the desired pressure range.
    • Ensure all connections are securely tightened to prevent leaks.
  2. Evacuation:
    • Begin by evacuating the McLeod gauge and the connected system using the vacuum pump.
    • Open the valve between the vacuum pump and the McLeod gauge to allow the pump to remove air and other gases from the system.
    • Continue evacuating until the pressure within the system reaches the desired low-pressure level, typically below 10^-3 torr.
  3. Capture Gas Sample:
    • Once the desired pressure is achieved, close the valve between the vacuum pump and the McLeod gauge to isolate the system.
    • Open the valve to the gas source whose pressure you want to measure. This could be a vacuum chamber, gas cylinder, or another source.
    • Allow the gas to flow into the evacuated McLeod gauge, filling the volume at the desired pressure.
  4. Isolation and Compression:
    • Close the valve to the gas source once the desired volume of gas is captured within the McLeod gauge.
    • Use a valve or pinch-off tube to isolate the captured gas from the rest of the system.
    • Begin compressing the captured gas by moving the piston or screw mechanism within the McLeod gauge. This reduces the volume of the captured gas while maintaining a constant temperature.
  5. Measurement:
    • As you compress the gas, measure the volume of the gas chamber at each pressure increment using the graduated scale or volume markings on the McLeod gauge.
    • Record the volume and corresponding pressure readings at each step of compression.
  6. Pressure Calculation:
    • Use Boyle's Law (P1V1 = P2V2) to calculate the pressure of the captured gas at each volume increment.
    • Plot a pressure-volume curve using the recorded data points to visualize the relationship between pressure and volume.
  7. Pressure Measurement:
    • Determine the pressure of the captured gas by extrapolating the pressure-volume curve to zero volume. This represents the pressure of the gas when it completely fills the McLeod gauge.
    • Record this pressure as the measurement of the gas pressure in the system.
  8. Release and Reset:
    • Release the captured gas from the McLeod gauge by opening the valve or releasing the pinch-off tube.
    • Reset the McLeod gauge by evacuating it again to prepare for the next pressure measurement.
It's important to follow proper safety procedures when working with vacuum systems and high-pressure gases to avoid accidents or injury. Additionally, calibration and verification of the McLeod gauge should be performed regularly to ensure accurate pressure measurements.
