Inverted Bell Pressure Gauges
Inverted bell pressure gauges, also known as inverted pressure gauges or upside-down pressure gauges, are a type of pressure gauge designed to measure low pressures or vacuum conditions. Unlike traditional pressure gauges where the pointer moves clockwise with increasing pressure, in inverted bell pressure gauges, the pointer moves counter-clockwise or in the opposite direction.
Here are some key features and characteristics of inverted bell pressure gauges:
  1. Design: Inverted bell pressure gauges feature a unique design where the dial face and pointer are oriented in an inverted manner compared to conventional pressure gauges. The pointer is located at the bottom of the dial face, and the scale typically ranges from 0 to negative values, representing vacuum levels or low pressures.
  2. Applications: Inverted bell pressure gauges are commonly used in applications where vacuum levels or low pressures need to be accurately measured. These applications may include vacuum systems, pneumatic conveying systems, HVAC systems, laboratory equipment, and process industries where negative pressure conditions occur.
  3. Measurement Range: Inverted bell pressure gauges are designed to measure pressure ranges typically below atmospheric pressure. The measurement range may vary depending on the specific model and application requirements but generally covers vacuum levels from near 0 to several inches of mercury (inHg) or millibars (mbar).
  4. Accuracy and Sensitivity: Inverted bell pressure gauges offer high accuracy and sensitivity in measuring low pressures or vacuum conditions. The scale markings and pointer movement are optimized for precise measurement and easy readability even at low pressure levels.
  5. Operating Principle: The operating principle of inverted bell pressure gauges is similar to that of traditional pressure gauges. They contain a pressure sensing element, such as a diaphragm or Bourdon tube, connected to the inlet port. As the pressure decreases or becomes negative, the sensing element deflects in the opposite direction, causing the pointer to move counter-clockwise on the dial face.
  6. Construction Materials: Inverted bell pressure gauges are typically constructed using materials that are compatible with the measured media and environmental conditions. Common materials include stainless steel, brass, aluminum, and various plastics.
  7. Mounting Options: Inverted bell pressure gauges may offer different mounting options to suit various installation requirements. They can be bottom mounted, panel mounted, or flush mounted depending on the application and space constraints.
In summary, inverted bell pressure gauges are specialized instruments designed for accurate measurement of low pressures or vacuum conditions. They offer reliable performance, high accuracy, and ease of readability, making them suitable for a wide range of industrial, commercial, and laboratory applications.
