Resistance level detectors - Working principle
Resistance level detectors, also known as resistance level sensors or resistance level transmitters, operate based on the principle of electrical resistance change caused by the liquid level variation. These sensors are commonly used in various industries to measure the level of liquid in tanks or vessels. Here's the working principle of resistance level detectors:
  1. Sensor Construction:
    • A resistance level detector typically consists of a sensing element made of a conductive material, such as a wire or a film, which is mounted vertically inside the tank. The sensor may be in the form of a probe, rod, or tape, depending on the specific application and tank design.
  2. Electrical Resistance Variation:
    • As the liquid level in the tank changes, the portion of the sensing element submerged in the liquid also changes. When the sensing element is immersed in the liquid, it experiences a change in electrical resistance due to the conductivity of the liquid.
  3. Resistance Measurement:
    • The resistance level detector is connected to a measurement circuit or transmitter, which applies a constant electrical voltage or current to the sensing element. The circuit measures the electrical resistance of the sensing element, which varies according to the level of liquid covering the element.
  4. Calibration and Conversion:
    • The resistance measurement obtained from the sensor is calibrated to correspond to the liquid level in the tank. Calibration is typically performed by correlating the resistance values at different levels with the actual liquid levels in the tank using calibration curves or tables.
  5. Output Signal:
    • The resistance level detector converts the measured resistance value into an output signal proportional to the liquid level. This output signal may be in the form of an analog voltage, current, or resistance, or a digital signal such as a Modbus or HART protocol.
  6. Display or Control:
    • The output signal from the resistance level detector can be displayed on a local indicator or transmitted to a control system for further processing. In automated systems, the signal may be used to control pumps, valves, or alarms based on the liquid level measurement.
  7. Temperature Compensation:
    • Some resistance level detectors incorporate temperature compensation mechanisms to account for changes in the electrical resistance of the sensing element caused by temperature variations. This ensures accurate level measurement over a wide range of operating temperatures.
Resistance level detectors are suitable for a wide range of liquid types and tank configurations. They offer advantages such as simplicity, reliability, and compatibility with various liquids. However, they may be affected by factors such as electrical conductivity variations, coating or fouling of the sensing element, and temperature effects, which should be considered during installation and operation.
