Selection of level instrument
Selecting the appropriate level instrument depends on several factors, including the characteristics of the substance being measured, the operating environment, accuracy requirements, safety considerations, and budget constraints. Here are some steps to guide the selection process:
  1. Understand the Properties of the Substance:
    • Determine whether the substance is a liquid, solid, or slurry.
    • Consider the physical properties such as viscosity, density, conductivity, and corrosiveness of the substance.
  2. Evaluate Environmental Conditions:
    • Assess the operating temperature and pressure range.
    • Consider factors such as vibration, shock, humidity, and potential exposure to hazardous materials.
  3. Define Accuracy and Reliability Requirements:
    • Determine the required level of measurement accuracy and precision.
    • Assess the reliability and failure rates of different technologies, especially in critical applications.
  4. Consider Installation and Maintenance:
    • Evaluate ease of installation, calibration, and maintenance requirements for each technology.
    • Assess factors such as accessibility, space constraints, and compatibility with existing infrastructure.
  5. Review Safety and Regulatory Requirements:
    • Ensure compliance with relevant safety standards and regulations (e.g., ATEX, FM, CSA).
    • Consider any industry-specific guidelines or best practices.
  6. Compare Available Technologies:
    • Ultrasonic Level Measurement: Suitable for non-contact measurement of liquids, solids, and slurry in various tank sizes and shapes. Consider factors such as temperature, presence of foam or vapor, and tank geometry.
    • Radar Level Measurement: Suitable for non-contact measurement of liquids, solids, and slurry in harsh environments with temperature extremes, turbulence, or vapor. Consider factors such as antenna size, signal attenuation, and obstruction.
    • Capacitance Level Measurement: Suitable for continuous or point level measurement of conductive or non-conductive liquids, solids, or slurry. Consider factors such as dielectric constant, coating or buildup, and temperature stability.
    • Guided Wave Radar (GWR): Suitable for continuous level measurement of liquids, solids, or slurry in narrow or restricted tanks with challenging conditions such as foam, vapor, or turbulence. Consider factors such as probe length, signal attenuation, and interface detection capability.
    • Pressure Transmitters: Suitable for measuring the hydrostatic pressure of liquids in tanks or vessels. Consider factors such as pressure range, material compatibility, and installation method.
    • Float Level Switches: Suitable for point level detection of liquids in tanks or vessels. Consider factors such as float material, switch mechanism, and installation orientation.
    • Magnetostrictive Level Transmitters: Suitable for high-accuracy continuous level measurement of liquids in various tank sizes and shapes. Consider factors such as installation method, signal processing, and temperature compensation.
  7. Consult with Experts and Suppliers:
    • Seek advice from industry experts, engineers, and suppliers with experience in level measurement.
    • Request product demonstrations, technical specifications, and references from potential suppliers.
By carefully considering these factors and following a systematic evaluation process, you can select the most suitable level instrument for your specific application, ensuring accurate and reliable level measurement while meeting safety, regulatory, and budgetary requirements.
