Sourcing and Valve calibration using Loop calibrator
Calibrating a control valve using a loop calibrator involves adjusting the valve's position or control signal to ensure accurate and reliable operation within a control loop. Here's a step-by-step guide on how to perform valve calibration using a loop calibrator:
  1. Gather Equipment:
    • Obtain a loop calibrator capable of sourcing a control signal (e.g., 4-20 mA) and measuring current.
    • Ensure that the loop calibrator is properly calibrated and in good working condition.
    • Have any necessary tools, documentation, and safety equipment ready.
  2. Prepare Workspace:
    • Set up a clean and safe workspace near the control valve, with access to power outlets and calibration equipment.
    • Ensure that the control valve is isolated from the process and that any necessary safety precautions are followed.
  3. Establish Baseline:
    • Determine the current operating conditions of the control loop, including the desired setpoint and control range.
    • Measure and record the current position or output signal of the control valve to establish a baseline reference.
  4. Connect Loop Calibrator:
    • Connect the loop calibrator to the control loop, either by connecting directly to the control system or by bypassing the control system and connecting directly to the control valve.
    • Ensure that all connections are secure and properly configured according to the manufacturer's instructions.
  5. Source Control Signal:
    • Use the loop calibrator to source a control signal (e.g., 4 mA for closed, 20 mA for open) to the control valve.
    • Monitor the response of the control valve and observe any changes in position or output signal.
  6. Adjust Valve Position:
    • If the control valve does not respond as expected to the sourced control signal, make adjustments to the valve's position using manual overrides or control system settings.
    • Use the loop calibrator to verify the position or output signal of the control valve and make further adjustments as necessary.
  7. Verify Calibration:
    • Once the control valve responds correctly to the sourced control signal, verify its calibration by sourcing different control signals across its operating range.
    • Measure and record the position or output signal of the control valve at each calibration point and compare it to the expected values.
  8. Fine-Tune Calibration:
    • Fine-tune the calibration by making small adjustments to the control valve's position or control signal to ensure accurate and reliable operation across its entire range.
    • Repeat the calibration process several times, adjusting the control signal and observing the valve's response to confirm consistency and repeatability.
  9. Document Results:
    • Document the calibration process, including the control signals applied, valve positions or output signals measured, adjustments made, and any observed errors or deviations.
    • Prepare a calibration certificate or report to provide evidence of the control valve's calibration for future reference.
  10. Finalize Calibration:
    • Once satisfied with the calibration results, finalize the process by disconnecting the loop calibrator from the control valve and returning the system to normal operation.
    • Ensure that the control valve is properly integrated into the control loop and that any necessary adjustments are made to the control system settings.
By following these steps, you can effectively calibrate a control valve using a loop calibrator, ensuring accurate and reliable operation within a control loop. It's essential to follow manufacturer guidelines, industry best practices, and organizational procedures to perform effective valve calibration and maintain the integrity of control systems.
