Tilt level switches
Tilt level switches are devices used to detect the presence or absence of a liquid at a specific level within a tank or vessel by measuring the tilt or inclination of the switch. These switches are typically installed horizontally at the desired level within the tank, and they activate or deactivate based on the change in tilt angle caused by the presence or absence of the liquid.
Here's how tilt level switches work and some considerations for their use:
  1. Principle of Operation:
    • Tilt level switches consist of a buoyant float or ball attached to a lever arm or pendulum mechanism.
    • When the liquid level rises, the buoyant float or ball lifts the lever arm, causing the switch to tilt or pivot.
    • The tilt or pivot action triggers the switch mechanism, either opening or closing an electrical contact to indicate the liquid level.
  2. Advantages:
    • Simple design: Tilt level switches have a straightforward mechanical design, making them easy to install and maintain.
    • Suitable for point level detection: Tilt switches are typically used for point level detection, indicating when the liquid level has reached a specific height within the tank.
    • Reliable operation: Tilt switches provide a reliable indication of liquid presence or absence, with no moving parts in contact with the liquid.
  3. Limitations:
    • Limited adjustability: Tilt switches are typically set to trigger at a specific angle, which may not be easily adjustable in the field.
    • Limited suitability for turbulent conditions: Tilt switches may be affected by agitation or turbulence within the tank, leading to false triggering or unreliable operation.
    • Limited application in viscous liquids: Tilt switches may not function effectively in applications with highly viscous liquids, as the buoyant float or ball may not move freely.
  4. Applications:
    • Tilt level switches are commonly used in various industries for point level detection in tanks, vessels, sumps, and reservoirs.
    • They are suitable for applications such as pump control, high-level alarms, low-level alarms, and overfill protection.
    • Tilt switches can be used with a wide range of liquids, including water, chemicals, oils, and fuels.
When selecting a tilt level switch for your application, consider factors such as the type of liquid, operating conditions, accuracy requirements, installation constraints, and budget considerations. Ensure that the switch is compatible with the properties of the liquid and the environmental conditions within the tank. Additionally, consider the reliability and durability of the switch to ensure long-term performance and minimize maintenance requirements.
