Valve positioner and its working
A valve positioner is a device used in control systems to accurately position a control valve based on an input signal, typically from a control system or a process variable. It ensures that the valve's position corresponds precisely to the desired setpoint, allowing for accurate control of flow, pressure, or other process variables. Here's how a valve positioner works and its main components:
  1. Working Principle:
    • A valve positioner operates by comparing the position of the valve actuator (such as a pneumatic or electric actuator) with a reference signal (setpoint) provided by the control system.
    • The positioner receives the reference signal and measures the actual position of the valve actuator using feedback mechanisms, such as a potentiometer or a position sensor.
    • Based on the difference between the reference signal and the actual position, the positioner generates a control signal to adjust the actuator's position accordingly.
    • The control signal is transmitted to the actuator, causing it to move the valve stem or actuator shaft to the desired position, thus adjusting the flow rate or other process parameters.
  2. Components:
    • Controller: The controller compares the reference signal from the control system with the feedback signal from the valve position sensor to determine the error (difference) between the desired and actual valve positions.
    • Position Sensor: The position sensor measures the actual position of the valve actuator and provides feedback to the controller. Common types of position sensors include potentiometers, linear variable displacement transducers (LVDTs), and digital position sensors.
    • Pneumatic or Electric Actuator: The actuator is responsible for moving the valve stem or actuator shaft to the desired position based on the control signal from the positioner.
    • I/P Converter (for pneumatic actuators): In pneumatic control systems, an I/P converter (current-to-pressure converter) is used to convert the electrical control signal from the positioner into a pneumatic signal (air pressure) to actuate the pneumatic actuator.
    • Feedback Mechanism: The feedback mechanism provides information about the valve position to the positioner, allowing it to continuously adjust the actuator position to match the desired setpoint.
  3. Operation:
    • The control system sends a reference signal to the valve positioner, indicating the desired valve position (e.g., open, closed, or partially open).
    • The positioner compares the reference signal with the feedback signal from the position sensor to determine the error.
    • Based on the error, the positioner generates a control signal to adjust the actuator's position.
    • The actuator moves the valve stem or actuator shaft to the desired position, regulating the flow rate or process variable accordingly.
    • The positioner continuously monitors the valve position and makes adjustments as necessary to maintain the desired setpoint.
Valve positioners are essential for ensuring precise control and optimal performance of control valves in various industrial applications, including process control, oil and gas, chemical processing, power generation, and water treatment. They help improve control system accuracy, reduce process variability, and enhance overall system reliability.
