What are important accessories used for pressure transmitter?
Several accessories are commonly used with pressure transmitters to enhance their performance, protect them from environmental factors, and facilitate installation and operation. Some important accessories for pressure transmitters include:
  1. Mounting Brackets: Mounting brackets are used to securely attach the pressure transmitter to a mounting surface, such as a pipe or wall. They provide stability and support, ensuring proper alignment and orientation of the transmitter.
  2. Pressure Snubbers: Pressure snubbers are devices installed between the process connection and the pressure transmitter to dampen pressure spikes and pulsations. They protect the transmitter from damage and extend its lifespan by reducing mechanical stress and wear.
  3. Isolation Diaphragms: Isolation diaphragms are installed between the process fluid and the pressure transmitter to protect the transmitter from corrosive or abrasive media. They prevent direct contact between the process fluid and sensitive transmitter components, reducing the risk of damage or contamination.
  4. Calibration Tools: Calibration tools, such as hand pumps and pressure calibration gauges, are used to calibrate pressure transmitters to ensure accurate and reliable measurements. They provide a reference pressure source for adjusting and verifying the transmitter's output.
  5. Junction Boxes: Junction boxes are enclosures used to house electrical connections and terminal blocks for wiring the pressure transmitter to the control system or data acquisition system. They provide protection from environmental hazards and facilitate cable management.
  6. Vent Valves: Vent valves are used to release trapped air or gases from the pressure transmitter and process connection during installation or maintenance. They ensure proper operation and accuracy by eliminating air pockets that can affect pressure measurements.
  7. Manifolds: Manifolds are piping assemblies that allow multiple pressure transmitters to be connected to a single process connection. They simplify installation, reduce piping complexity, and provide isolation between individual transmitters for maintenance or calibration purposes.
  8. Temperature Sensors: Temperature sensors, such as RTDs or thermocouples, may be installed alongside pressure transmitters to provide temperature compensation for accurate pressure measurements. They help correct for variations in ambient temperature that can affect transmitter performance.
  9. Sealants and Gaskets: Sealants and gaskets are used to ensure a leak-tight seal between the pressure transmitter and process connection. They prevent fluid leakage and contamination, maintaining the integrity of the measurement system.
  10. Cable Glands and Connectors: Cable glands and connectors are used to secure and seal the electrical wiring connections between the pressure transmitter and junction box or control system. They provide strain relief and protection against moisture and dust ingress.
These accessories are essential for ensuring the proper installation, operation, and maintenance of pressure transmitters in various industrial applications. The selection of accessories depends on the specific requirements of the application, environmental conditions, and the type of pressure transmitter being used.
