What are pyrometers? Types of pyrometers (Non contacting type temperature measurement)
Pyrometers are instruments used to measure high temperatures without making direct contact with the object being measured. They operate based on the principle of detecting the thermal radiation emitted by the object and converting it into a temperature reading. Pyrometers are commonly used in industrial processes, scientific research, and temperature monitoring applications where direct contact with the object is impractical or unsafe.
There are several types of pyrometers, each utilizing different techniques to measure temperature:
  1. Optical Pyrometers:
    • Total Radiation Pyrometers: Total radiation pyrometers measure the total thermal radiation emitted by an object across a broad spectrum of wavelengths. They are suitable for measuring temperatures of incandescent objects, such as hot metals, flames, and furnaces.
    • Two-Color Pyrometers: Two-color pyrometers measure the ratio of thermal radiation intensities at two different wavelengths, typically in the infrared spectrum. By comparing the intensities, the temperature of the object can be determined without knowledge of its emissivity.
  2. Infrared Pyrometers:
    • Single-Color Pyrometers: Single-color infrared pyrometers measure the thermal radiation emitted by an object at a specific wavelength within the infrared spectrum. They are commonly used for non-contact temperature measurements of solid objects, liquids, and gases in industrial and scientific applications.
    • Ratio Pyrometers: Ratio pyrometers measure the ratio of thermal radiation intensities at two different wavelengths within the infrared spectrum. Similar to two-color pyrometers, they compensate for variations in emissivity and atmospheric effects.
  3. Fiber-Optic Pyrometers:
    • Fiber-optic pyrometers use fiber-optic cables to transmit thermal radiation from the object to a remote sensor unit. They are suitable for measuring temperatures in confined spaces or hazardous environments where direct access is limited.
  4. Radiation Thermometers:
    • Radiation thermometers, also known as infrared radiation thermometers or infrared thermometers, measure the thermal radiation emitted by an object and convert it into a temperature reading. They are widely used for non-contact temperature measurements in industrial processes, HVAC systems, and medical applications.
  5. Pyrometric Cones:
    • Pyrometric cones, also known as ceramic cones or witness cones, are small ceramic objects designed to deform at specific temperatures. They are commonly used in ceramic and pottery kilns as a simple visual indicator of the temperature reached during firing.
Each type of pyrometer has its own advantages and limitations, depending on factors such as temperature range, accuracy, response time, and environmental conditions. Proper selection and calibration are essential to ensure accurate and reliable temperature measurements for specific applications.
