What is a V ball valve?
A V ball valve, also known as a V-port ball valve or a V-notch ball valve, is a type of quarter-turn valve that utilizes a ball with a V-shaped bore to control the flow of fluid. It is commonly used in applications requiring precise control over flow rates, such as in industrial processes, chemical processing, and water treatment.
Here's how a V ball valve works and some of its features:
  1. Construction: Like a traditional ball valve, a V ball valve consists of a spherical ball with a through-hole (bore) in the center. However, unlike a standard ball valve, the bore in a V ball valve is not circular but instead has a V-shaped notch or groove. This V-notch allows for precise control over the flow of fluid as the ball is rotated.
  2. Flow Control: By rotating the ball within the valve body, the V-notch can be aligned with the flow path to allow varying degrees of flow. The V-notch provides a linear flow characteristic, allowing for more accurate control over flow rates compared to standard ball valves, especially in applications requiring throttling or modulating control.
  3. Actuation: V ball valves can be manually operated using a handle or lever, or they can be equipped with pneumatic, electric, or hydraulic actuators for automated control.
  4. Materials and Configurations: V ball valves are available in a variety of materials to suit different applications, including stainless steel, brass, and various plastics. They come in various configurations, including two-way (shut-off), three-way (diverter), and multi-port designs.
  5. Applications: V ball valves are commonly used in applications where precise flow control is required, such as in the chemical and petrochemical industries, water treatment plants, power generation facilities, and process control systems. They are particularly well-suited for applications involving viscous fluids, slurries, or fluids with suspended solids.
Overall, V ball valves offer precise flow control, reliability, and versatility, making them suitable for a wide range of industrial applications where accurate regulation of fluid flow is critical.
