What is cascade control loop? Advantages of the cascade control loop
A cascade control loop is a control strategy used in industrial automation to improve the performance and stability of a control system, particularly in processes with complex dynamics or interactions between multiple variables. In a cascade control loop, there are two or more control loops nested within each other, with the output of the primary (outer) loop serving as the setpoint for the secondary (inner) loop. The secondary loop then adjusts a secondary manipulated variable to maintain the primary process variable at its setpoint, while the primary loop adjusts the primary manipulated variable to achieve the desired overall control objective.
Here's how a cascade control loop works:
  1. Primary Loop:
    • The primary loop controls the primary process variable (PV) directly related to the main control objective. It receives a setpoint (SP) and measures the process variable (PV) using sensors.
    • The primary loop adjusts a primary manipulated variable (MV) to regulate the primary process variable (PV) at its setpoint (SP).
  2. Secondary Loop:
    • The secondary loop controls a secondary process variable (SV) that affects the primary process variable (PV) but is not directly controlled by the primary loop.
    • The secondary loop receives the output (MV) of the primary loop as its setpoint and measures the secondary process variable (SV) using sensors.
    • The secondary loop adjusts a secondary manipulated variable (SMV) to regulate the secondary process variable (SV) at the setpoint provided by the primary loop.
  3. Interactions:
    • The output of the secondary loop (SMV) indirectly influences the primary process variable (PV) by affecting the secondary process variable (SV).
    • The output of the primary loop (MV) is adjusted based on the deviation between the primary process variable (PV) and its setpoint (SP), taking into account the effect of the secondary loop's control action.
  4. Advantages of Cascade Control:
    • Improved Performance: Cascade control can provide faster response times and better disturbance rejection compared to single-loop control systems. By controlling the secondary variable more directly, cascade control reduces the effects of disturbances on the primary variable.
    • Enhanced Stability: Cascade control helps stabilize processes with complex dynamics or long time constants by decoupling the control loops and mitigating interactions between variables.
    • Reduced Variability: Cascade control minimizes variations in the primary process variable by effectively isolating disturbances at the secondary level and preventing them from propagating to the primary level.
    • Flexibility: Cascade control allows for independent tuning of the primary and secondary loops, enabling optimization of control performance for each variable separately.
    • Improved Setpoint Tracking: Cascade control facilitates accurate setpoint tracking for the primary process variable by ensuring that changes in the setpoint are promptly and effectively translated into adjustments of the primary manipulated variable.
Overall, cascade control loops offer significant advantages in terms of performance, stability, and robustness, making them well-suited for controlling complex industrial processes with multiple interacting variables. However, cascade control requires careful design, tuning, and implementation to achieve optimal results.
