What is Dead Weight Tester ? How does it work?
A dead weight tester is a primary standard calibration instrument used to accurately measure and calibrate pressure instruments such as pressure gauges, transmitters, and transducers. It operates based on the principle of balancing the force of a known weight against the pressure exerted by a fluid within a sealed chamber. Here's how it works:
  1. Basic Components:
    • Piston and Cylinder: The dead weight tester consists of a piston and cylinder assembly, where the piston is precisely machined to fit snugly within the cylinder.
    • Weights: Known masses (weights) are placed on top of the piston to create the pressure to be measured.
    • Sealing Fluid: The chamber between the piston and cylinder is filled with a fluid (often oil or water) to provide hydraulic pressure.
  2. Assembly:
    • The dead weight tester is placed on a stable surface, and the weights are carefully stacked on top of the piston.
    • The weights exert a downward force on the piston, creating a pressure inside the sealed chamber.
  3. Pressure Measurement:
    • The pressure exerted by the fluid inside the sealed chamber is directly proportional to the applied weight and the area of the piston.
    • The pressure can be calculated using the formula: Pressure = Force / Area.
  4. Calibration:
    • The dead weight tester is calibrated using traceable standards to ensure accuracy. The weights used must be accurately calibrated, and the dimensions of the piston and cylinder must be precisely measured.
    • The dead weight tester is typically calibrated at various pressure points across its range to verify its accuracy.
  5. Calibration Procedure:
    • To calibrate a pressure instrument, the dead weight tester is connected to the instrument under test through a pressure line.
    • The pressure within the instrument is adjusted until it matches the pressure exerted by the weights on the dead weight tester.
    • The pressure reading on the instrument is compared to the known pressure generated by the dead weight tester, allowing for calibration adjustments if necessary.
  6. Advantages:
    • High Accuracy: Dead weight testers provide highly accurate pressure measurements, typically with uncertainties as low as 0.01% of the full-scale range.
    • Primary Standard: Dead weight testers are considered primary standards and provide traceable measurements to international standards.
    • Wide Range: Dead weight testers can cover a wide pressure range, from low to high pressures, making them suitable for calibrating various pressure instruments.
  7. Limitations:
    • Time-consuming: Dead weight testing can be time-consuming, especially when calibrating pressure instruments across multiple pressure points.
    • Complex Setup: Dead weight testers require careful setup and precise measurement techniques to ensure accurate results.
    • Not Portable: Dead weight testers are typically large and heavy instruments, making them unsuitable for field calibration applications.
In summary, dead weight testers are highly accurate and reliable instruments used for calibrating pressure instruments across a wide range of pressures. They serve as primary standards in pressure metrology and play a critical role in ensuring the accuracy and reliability of pressure measurements in various industries.
