What is DTS (Distributed temperature sensing)?
Distributed Temperature Sensing (DTS) is a technology used to measure temperature continuously along the length of a fiber optic cable. It operates based on the principle of optical time-domain reflectometry (OTDR), which involves sending pulses of light down a fiber optic cable and analyzing the backscattered light to determine temperature variations along the cable.
Here's how DTS typically works:
  1. Fiber Optic Cable: A length of fiber optic cable, usually single-mode, is deployed in the area where temperature monitoring is required. The cable can be installed along pipelines, power cables, wellbores, or other infrastructure.
  2. Light Pulse Injection: A laser or LED light source sends short pulses of light down the fiber optic cable at regular intervals.
  3. Backscattered Light Analysis: As the light travels along the fiber, it interacts with the glass and the surrounding environment. Some of the light is scattered back toward the source due to changes in temperature along the fiber. This backscattered light carries information about the temperature profile of the surroundings.
  4. Temperature Calculation: By analyzing the time delay and intensity of the backscattered light, the DTS system can calculate the temperature at each point along the fiber optic cable.
  5. Data Output: The temperature data is typically processed and visualized in real-time, allowing users to monitor temperature variations and trends along the entire length of the cable.
DTS systems offer several advantages for temperature monitoring applications:
  • Continuous Monitoring: DTS provides continuous temperature monitoring along the entire length of the fiber optic cable, offering a detailed view of temperature variations over time and space.
  • High Spatial Resolution: DTS systems can achieve high spatial resolution, allowing users to detect temperature changes with precision, even over long distances.
  • Remote Sensing: DTS can be deployed in remote or inaccessible locations, enabling temperature monitoring in harsh environments or hazardous areas.
  • Versatility: DTS systems can be used in various applications, including environmental monitoring, oil and gas pipeline monitoring, power cable monitoring, industrial process control, and more.
Overall, DTS is a powerful and versatile technology for temperature monitoring applications that require continuous, distributed measurements over large areas or long distances.
