What is Gas Chromatography? How gas Chromatography is done?
Gas chromatography (GC) is a widely used analytical technique for separating and analyzing volatile compounds in a gas sample. It is commonly employed in various fields such as chemistry, biochemistry, environmental science, forensics, pharmaceuticals, and petrochemicals. Gas chromatography allows for the identification and quantification of individual components within a mixture.
Here's how gas chromatography is typically performed:
  1. Sample Preparation:
    • The sample to be analyzed is typically prepared by injecting a small volume of gas or a solution containing the analytes into the gas chromatograph.
    • Sample preparation techniques such as dilution, extraction, derivatization, or concentration may be employed depending on the nature of the sample and the analytes of interest.
  2. Injection:
    • The prepared sample is injected into the gas chromatograph through a syringe or an automatic injector.
    • The sample is introduced into the gas chromatograph's injector port, where it is vaporized and injected into the chromatographic column.
  3. Separation:
    • Inside the gas chromatograph, the sample components are separated based on their differential partitioning between a stationary phase and a mobile phase (carrier gas).
    • The mobile phase, typically an inert gas such as helium or nitrogen, carries the sample components through the chromatographic column.
    • The stationary phase, coated on the interior walls of the chromatographic column, interacts with the sample components based on their affinity, size, polarity, and other physicochemical properties.
    • As the sample components travel through the column, they are distributed between the stationary and mobile phases, leading to differential migration rates and separation.
  4. Detection:
    • After separation, the individual components of the sample elute from the chromatographic column and enter the detector.
    • Various types of detectors may be used in gas chromatography, including flame ionization detectors (FID), thermal conductivity detectors (TCD), electron capture detectors (ECD), and mass spectrometers (MS).
    • The detector generates an electrical signal proportional to the concentration of each analyte as it elutes from the column.
    • The signal is amplified, digitized, and recorded by a data acquisition system for subsequent analysis.
  5. Analysis and Interpretation:
    • The recorded chromatogram, which plots detector response (signal intensity) against time or retention time, is analyzed to identify and quantify the individual components in the sample.
    • Retention times and peak shapes are compared to those of known standards or reference compounds to identify the analytes.
    • Quantification is typically performed by measuring peak areas or heights and comparing them to calibration curves generated using standard solutions of known concentration.
  6. Data Processing and Reporting:
    • The raw chromatographic data may undergo processing, such as baseline correction, peak integration, and data normalization, using specialized software.
    • Analytical results, including compound identification and quantification, are reported in a suitable format for interpretation and decision-making.
Gas chromatography is a versatile and powerful analytical technique with applications in a wide range of industries. It offers high sensitivity, selectivity, and resolution for analyzing complex mixtures of volatile compounds.
