Why glycerin is used in pressure gauge?
Glycerin, a colorless, odorless, and non-toxic liquid, is commonly used as a fill fluid in certain types of pressure gauges. Here are several reasons why glycerin is used in pressure gauges:
  1. Damping: One of the primary reasons glycerin is used in pressure gauges is for damping. Glycerin helps dampen the movement of the gauge pointer, reducing pointer oscillation and making it easier to read the pressure indication. This is particularly useful in applications where pressure fluctuations are common or where rapid changes in pressure occur.
  2. Protection: Glycerin acts as a protective barrier between the internal components of the pressure gauge and the process fluid being measured. It helps prevent corrosion, oxidation, and damage to sensitive components, such as the Bourdon tube or diaphragm, by providing a cushioning effect.
  3. Vibration Resistance: Glycerin-filled pressure gauges are often used in applications where vibration or mechanical shock is present. The glycerin fill fluid absorbs and dampens vibrations, reducing the risk of damage to the gauge and ensuring accurate and stable pressure readings.
  4. Temperature Compensation: Glycerin has a relatively low coefficient of thermal expansion, which means it expands and contracts less with changes in temperature compared to other fill fluids. This property helps maintain consistent pressure readings over a wide temperature range, improving the accuracy of the gauge.
  5. Viscosity: Glycerin has a higher viscosity compared to water or other fill fluids. This higher viscosity helps to minimize the effects of pulsation or pressure spikes in the process fluid, resulting in smoother gauge readings.
  6. Safety: Glycerin is non-toxic and environmentally friendly, making it safe to use in pressure gauges that come into contact with food, pharmaceuticals, or other sensitive materials. It poses no health risks to operators and does not pose a threat to the environment if accidentally released.
  7. Ease of Handling: Glycerin is readily available, cost-effective, and easy to handle. Its low volatility and stable properties make it a practical choice for filling pressure gauges, requiring minimal maintenance and providing long-term stability.
Overall, glycerin is a versatile fill fluid that offers several benefits for use in pressure gauges, including damping, protection, vibration resistance, temperature compensation, viscosity, safety, and ease of handling. These properties make glycerin-filled pressure gauges suitable for a wide range of industrial applications where accurate and reliable pressure measurement is essential.
