INVT GD18 Series 2in1, GD10 Series Mini & GD800 Pro Series Drive
416
Nov 18, 2024 5:33 am
END fault in an INVT GD10 drive typically indicates that the drive has reached its end-of-life or a predefined time limit.
Common Causes of END Faults:
Time-Based Limitation:
- The drive may have a built-in time limit, after which it will trigger an END fault.
- This limit is often set by the manufacturer to ensure the reliability and safety of the drive.
Internal Component Wear:
- Over time, internal components like capacitors, power modules, or the control board may degrade, leading to performance issues and eventually an END fault.
Software or Firmware Issues:
- Software or firmware bugs or corruption can cause unexpected behavior and trigger the END fault.
Check the Drive's Time Limit:
- Consult the drive's manual to determine if there is a built-in time limit.
- If the limit has been reached, you may need to replace the drive.
Inspect Internal Components:
- Visually inspect the drive for any signs of damage, overheating, or loose connections.
- Consult a qualified technician for a more thorough inspection.
Update Firmware:
- If available, update the drive's firmware to the latest version to address potential bugs and improve performance.
