OC1 fault in INVT GD10 drive
OC1 fault in INVT GD10 drive indicates an overcurrent fault during acceleration. This means the motor is drawing more current than the drive can handle during startup.
Common Causes:
  1. Rapid Acceleration: If the acceleration time is set too short, the motor may draw excessive current during the initial acceleration phase.
  2. Mechanical Load: A heavy mechanical load or a mechanical obstruction can cause the motor to draw more current.
  3. Incorrect Motor Parameter Settings: If the motor parameters are not configured correctly, the drive may miscalculate the required current.
  4. Power Supply Issues: Insufficient power supply or voltage fluctuations can also trigger the OC1 fault.
  1. Check Acceleration Time:
    • Use the drive's programming software to adjust the acceleration time to a slower value.
    • Start with a longer acceleration time and gradually reduce it until the fault disappears.
  2. Inspect Mechanical Load:
    • Ensure that the motor shaft rotates freely and there are no mechanical obstructions.
    • Check for any binding or excessive friction in the mechanical system.
  3. Verify Motor Parameters:
    • Ensure that the motor's rated power, voltage, and current are correctly entered in the drive's parameter settings.
    • Consult the motor's nameplate for accurate values.
  4. Check Power Supply:
    • Verify that the power supply voltage and current are within the specified range.
    • Ensure that the power supply is capable of delivering the required power to the drive.
  5. Reset the Drive:
    • Turn off the power supply to the drive and wait for a few minutes.
    • Turn the power back on and try to restart the motor.
