OC2 fault in INVT GD10 drive
OC2 fault in INVT GD10 drive indicates an overcurrent fault during deceleration. This means the motor is drawing more current than the drive can handle while slowing down.
Common Causes:
  1. Rapid Deceleration: If the deceleration time is set too short, the motor may draw excessive current during the braking phase.
  2. Heavy Mechanical Load: A heavy mechanical load or a mechanical obstruction can cause the motor to draw more current during deceleration.
  3. Incorrect Motor Parameter Settings: If the motor parameters are not configured correctly, the drive may miscalculate the required current during deceleration.
  4. Internal Drive Faults: In rare cases, internal faults within the drive itself can trigger the OC2 fault.
  1. Check Deceleration Time:
    • Use the drive's programming software to adjust the deceleration time to a slower value.
    • Start with a longer deceleration time and gradually reduce it until the fault disappears.
  2. Inspect Mechanical Load:
    • Ensure that the motor shaft rotates freely and there are no mechanical obstructions.
    • Check for any binding or excessive friction in the mechanical system.
  3. Verify Motor Parameters:
    • Ensure that the motor's rated power, voltage, and current are correctly entered in the drive's parameter settings.
    • Consult the motor's nameplate for accurate values.
  4. Check for Internal Faults:
    • If the above steps do not resolve the issue, it may be necessary to inspect the drive's internal components or consult with a qualified technician.
  5. Reset the Drive:
    • Turn off the power supply to the drive and wait for a few minutes.
