INVT GD18 Series 2in1, GD10 Series Mini & GD800 Pro Series Drive
495
Nov 16, 2024 12:22 pm
OC3 fault in INVT GD10 drive indicates an overcurrent fault during constant speed operation. This means the motor is drawing more current than the drive can handle while running at a steady speed.
Common Causes:
- Mechanical Overload: The motor may be overloaded due to excessive mechanical load or friction.
- Incorrect Motor Parameter Settings: If the motor parameters are not configured correctly, the drive may miscalculate the required current.
- Power Supply Issues: Insufficient power supply or voltage fluctuations can also trigger the OC3 fault.
- Internal Drive Faults: In rare cases, internal faults within the drive itself can trigger the OC3 fault.
- Check Mechanical Load:
- Ensure that the motor shaft rotates freely and there are no mechanical obstructions.
- Check for any binding or excessive friction in the mechanical system.
- Verify Motor Parameters:
- Ensure that the motor's rated power, voltage, and current are correctly entered in the drive's parameter settings.
- Consult the motor's nameplate for accurate values.
- Check Power Supply:
- Verify that the power supply voltage and current are within the specified range.
- Ensure that the power supply is capable of delivering the required power to the drive.
- Check for Internal Faults:
- If the above steps do not resolve the issue, it may be necessary to inspect the drive's internal components.
