INVT GD18 Series 2in1, GD10 Series Mini & GD800 Pro Series Drive
563
Nov 18, 2024 5:07 am
UV fault in an INVT GD10 inverter indicates an Under Voltage condition. This means the input voltage to the drive has fallen below a specified threshold.
Common Causes of UV Faults:
Insufficient Input Voltage:
- Low Supply Voltage: Ensure the input voltage is within the specified range for the inverter.
- Voltage Drops: Check for voltage drops in the power supply cables, especially during high load conditions.
- Weak Power Supply: A weak or overloaded power supply can also cause undervoltage.
Internal Inverter Issues:
- Faulty Rectifier: A damaged rectifier can prevent proper voltage conversion.
- Capacitor Problems: Aging or damaged capacitors can reduce the DC bus voltage.
External Factors:
- Power Supply Fluctuations: Fluctuations in the power supply, such as brownouts or sags, can trigger the UV fault.
- Environmental Conditions: Extreme temperature or humidity can affect the performance of the inverter.
Verify Input Voltage:
- Use a voltmeter to measure the input voltage at the inverter terminals.
- Check for voltage drops in the power cables.
- Ensure the power supply is rated for the inverter's load.
Inspect Internal Components:
- Visually inspect the rectifier diodes and capacitors for any signs of damage or overheating.
- Consult the inverter's manual for specific troubleshooting guidelines and component replacement procedures.
Check Inverter Settings:
- Review the inverter's parameter settings to ensure they are appropriate for the application.
- Some settings, such as the undervoltage trip level, can be adjusted to accommodate specific power supply conditions.
