INVT GD20 Series, GD20-EU Series, GD20-UL Series & GD20-LA Series Drive
492
Apr 13, 2024 9:27 am
Cause : Communication error comes when there is no control data was received from the connected PLC when using serial communications.
"CE fault" indicate there in no communication between master & slave due to incorrect parameter or faulty wiring.
- The baud rate setting is incorrect.
- Fault occurs to the communication wiring.
- The communication address is wrong.
- There is strong interference to the communication.
- Set proper baud rate.
- Check the communication connection distribution.
- Set proper communication address.
- Chang or replace the connection distribution or improve the anti-interference capability.
