INVT GD20 Series, GD20-EU Series, GD20-UL Series & GD20-LA Series Drive
398
Apr 13, 2024 9:23 am
Cause : External terminal fault comes when external fault at multi-function input terminal or faults comes from external control circuit.
"EF" fault in "GD20" drive indicate an external device tripped an alarm function or wiring is incorrect or multi-function contact input setting is incorrect.
- Remove the cause of the external fault and reset the fault.
- Properly connect the signal lines to the terminals assigned for external fault detection.
- Reconnect the signal line.
- Change the terminal settings.
